How can I get ninjaflex to work with my XYZ da vinci aio printer?
How can I get ninjaflex to work with my XYZ da vinci aio printer? It doesn’t feed through the nozzle properly. It always loops out the side instead of pushing through the nozzle.
try printing more slower. For some other printers you can find on thingiverse something to print, which you can insert into the extruder. This part then fills out the space between the gear and the hot end so that the filament can not go other way.
I will try that. Thanks!
