@GrblGru many thanks for the latest features for 4 axis hotwire foam cutter software, one question in the preparation stage for swept wing cutting where can i adjust offset of foam block in order to get accurate cutting or should i just place foam block exactly in tge middle
Sorry, I’m afraid I don’t understand your question properly.
Unfortunately, I am not a model maker. Can you please explain your question in more detail ?
A sketch would be very helpful for me.
Hi Elsayad,
I’ll try to give you some help.
If the wing has a parallel shape, you can place the styrofoam block in any position.
If the wing has a tapered shape, then you have to pay close attention to the wire length setting in "Machine Manager =>X. Others=> Extension x mm (the actual length of the wire on your machine), enter the actual value in Width of the Stock Dimension on which you will have placed the two root and tip wing profiles.
At this point you have to put the styrofoam block exactly in the center of your styrofoam cutting machine, if everything is ok , you will get the wing in the correct dimensions.
You will always have to find the height position of the styrofoam block, my advice is to do some trials with scrap pieces of styrofoam, so you center the machining well without wasting unnecessary material.
I hope I have been clear in my exposition
Good cuts
Ferdi
I believe that I totally understand your question! To clarify it a little export from Jedicut software.
Here is the top view of the joiner part between two wings:
- length is only 120mm
- hotwire lenght is 830mm
- foam block is positionned 105mm away from the X1 axis
So you don’t have to position the block exactly in the middle of the machine.
Using GRBLGru “wingCreator” menu you can enter the profiles, cords, diedral and so on
and into the machine manager you will get the X dimensions and position of the block:
