Homing Error
(Anthony Bolgar) #1
Trying to set up a new machine and when I try to home it, I get a “Warning:Nothing to home” error in the console. Any clue as to why it is throwing that error @Arthur_Wolf ?
(Eric Lien) #2
Did you uncomment the endstop switches? And are you homing to the right location (home to min, home to max). I would check config on those.
(Anthony Bolgar) #3
This is my endstop config section:
# Endstops
# See http://smoothieware.org/endstops
endstops_enable                              true             # The endstop module is enabled by default and can be disabled here
#corexy_homing                               false            # Set to true if homing on a hbot or corexy
alpha_min_endstop                            1.24^            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop                           1.25^            # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_homing_direction                       home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
alpha_min                                    0                # This gets loaded as the current position after homing when home_to_min is set
alpha_max                                    800              # This gets loaded as the current position after homing when home_to_max is set
beta_min_endstop                             1.26^            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#beta_max_endstop                            1.27^            # Pin to read max endstop, uncomment this and comment the above if using max endstops
beta_homing_direction                        home_to_min      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
beta_min                                     0                # This gets loaded as the current position after homing when home_to_min is set
beta_max                                     325`              # This gets loaded as the current position after homing when home_to_max is set
gamma_min_endstop                            1.28^            # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#gamma_max_endstop                           1.29^            # Pin to read max endstop, uncomment this and comment the above if using max endstops
gamma_homing_direction                       home_to_max      # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
gamma_min                                    0                # This gets loaded as the current position after homing when home_to_min is set
gamma_max                                    85              # This gets loaded as the current position after homing when home_to_max is set
alpha_max_travel                             800              # Max travel in mm for alpha/X axis when homing
beta_max_travel                              500              # Max travel in mm for beta/Y axis when homing
gamma_max_travel                             500              # Max travel in mm for gamma/Z axis when homing
# Optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable                          false            # Set to true to enable X min and max limit switches
#beta_limit_enable                           false            # Set to true to enable Y min and max limit switches
#gamma_limit_enable                          false            # Set to true to enable Z min and max limit switches
# Endstops home at their fast feedrate first, then once the endstop is found they home again at their slow feedrate for accuracy
alpha_fast_homing_rate_mm_s                  50               # Alpha/X fast homing feedrate in mm/second
alpha_slow_homing_rate_mm_s                  25               # Alpha/X slow homing feedrate in mm/second
beta_fast_homing_rate_mm_s                   50               # Beta/Y  fast homing feedrate in mm/second
beta_slow_homing_rate_mm_s                   25               # Beta/Y  slow homing feedrate in mm/second
gamma_fast_homing_rate_mm_s                  4                # Gamma/Z fast homing feedrate in mm/second
gamma_slow_homing_rate_mm_s                  2                # Gamma/Z slow homing feedrate in mm/second
alpha_homing_retract_mm                      5                # Distance to retract from the endstop after it is hit for alpha/X
beta_homing_retract_mm                       5                # Distance to retract from the endstop after it is hit for beta/Y
gamma_homing_retract_mm                      1                # Distance to retract from the endstop after it is hit for gamma/Z
# Optional enable limit switches, actions will stop if any enabled limit switch is triggered (all are set for delta)
# Optional order in which axis will home, default is they all home at the same time,
# If this is set it will force each axis to home one at a time in the specified order
#homing_order                                 XYZ              # X axis followed by Y then Z last
#move_to_origin_after_home                    true            # Move XY to 0,0 after homing
#endstop_debounce_count                       100              # Uncomment if you get noise on your endstops, default is 100
#endstop_debounce_ms                          1                # Uncomment if you get noise on your endstops, default is 1 millisecond debounce
#home_z_first                                 true             # Uncomment and set to true to home the Z first, otherwise Z homes after XY
# End of endstop config
(Eric Lien) #4
You say “gamma_homing_direction” = “home_to_max”… but you have #gamma_max_endstop commented out:
(Anthony Bolgar) #5
Damn, I missed that, thanks!
(Eric Lien) #6
No problem. I know that error from experience :smile:
