Home Assistant projects for a first generation Raspberry Pi?
I was going through my closet the other day and found that I still have an original first generation raspberry pi (The model with the ethernet port).
Are there any good sources of resources for projects (preferably no-solder ones) involving hardware this old and Home Assistant?
Most of what I’ve seen needs newer models, as the old one is under powered in 2025.
I’ve already got my HA server set up, so I’m more looking for things that can be done with it, rather than setting up HA on it.
I’m looking for inspiration as well as instructions.
