Holy Crap! I now see why you guys like ABS! Corners are actually sharp
Holy Crap! I now see why you guys like ABS! Corners are actually sharp! I guess I’ll see about plumbing in a heated bed. #firstworldproblems
I’ve been quiet as I’m printing the Carriage for the igENTus, and noticed that the ABS failures are quite a bit lighter than the PLA carriage. Light is good.
Wait till it starts to warp! :frowning:
Since abs is less dense than PLA, when you buy by weight, you get more.
Wait a sec… if you’re getting better looking prints with ABS then PLA you are most likely printing PLA the wrong way. PLA needs to be printed a lot cooler, and needs to be cooled down pretty quickly after that (usually with an on-head fan)
(I’ve seen about 1000 better looking PLA printed Ultimaker robots then the one I see on this photo. Yes, we printed shitloads of these)
I’ll take a good close up of it this evening, then take tips on tuning. :slight_smile:
Then print again in pla, using my pla settings. (190-200 instead of 240)
I’m with David here - I find PLA a lot easier to print than ABS, and on small objects like the Robot, you absolutely, positively have to have active cooling.
