Hmm how much abuse you think the silicon heat pads can take? i just peeled mine off the aluminum. never folded the silicone off its self. was worked slowly at most of a 90 degree.
Dont think i broke the insides. but thats alot of tugging. ( insert thats what she said pun here)
All this to get my buddy to properly flatten my aluminum and find out the issue with the cupshape im getting
i sure hope that its not the glass!
Check the resistance of the leads. If it still lines up with what it should be for your wattage you should be fine.
Ah right! Totally forgot about that! Thanks Eric
I hope I get this weird bowl shape in my bed sorted.
Just the aluminum it’s bowl’d like a soup bowl
With the glass on it is bowl’d the opposite direction.
Oh and without glass it’s a bowl of around 0.1mm but with glass on. It’s 0.2mm in the respected directions mentioned.
I had to remove the silicone heater from my bed and stick it back on with no issues…
hmmmm 3M 467MP should do the trick to re adhere it right?
