Hiya!
I’m getting the Ares up and running and having some issues with CURA. Do you all use the stock profile that comes included? I saw the build area is “Rectangular” and the max z-height is 200mm
What are you using?
I was thinking elliptical may be a better approximation of build area.
I found @Nicolas_Liaudat 's profiles. Just import into cura?
Edit:
I got the beast up and running. really not liking the unreliability of the old octoprint so I’m going to have to dig into updating that at a later date.
My biggest problem is failure after random Z height. I think the filament may be binding or something because it is just not moving through the extruder.
1st print was 90% done and then it stopped laying down filament.
2nd print got the brim down and that was about it.
3rd print went about 15% through before it stopped laying filament.
