Hi there, Newbie here.
Has anyone used Lightburn with the K40 M2 Nano board ?
If so, may I ask what you set the board as …EG: Marlin ?
Cheers
NGA
Cheers
NGA
K40 whisperer is the only third party software that works with the M2 nano.
If you want to use LightBurn with your K40 you may consider upgrading the controller with a Cohesion3D Mini. it is designed to replace the M2 Nano board that ships with most K40’s. it installs in 10 minutes, usually without any modification. It is fully compatible with LightBurn, runs Smoothie & GRBL, and gives you PWM laser power control which is not possible with the stock board.
M2 Nano uses a proprietary closed protocol to talk to the host, hence the shitty chinese software. Afaik K40-whisperer is the only project to have reverse engineered that protocol and provided alternative software, anything else requires you to replace the board with something more open standards.
Thanks to all.
I have ordered a Co-Hesion 3D Mini now.
Appreciate the advice
Dr N
