Hi there! I'm running my banggood/Eleks Maker with a NanoPi Neo (smaller than an
Hi there! I’m running my banggood/Eleks Maker with a NanoPi Neo (smaller than an rPi) and LW3, and usually use one of my tiny laptops to access the webpage. However, if I change to use a different computer, the settings are gone. I do this so I can keep the engraver/cutter in an enclosure and not be tethered to it.
Is there a way to keep the json back up file locally on the Pi or better yet, is there a setting in LW3 that tells it to keep the json/settings, independent of the machine that is connecting to it via the web interface?
I’m probably not explaining this well. I know it is not an important feature, but a nicety.
