Hi there! I posted a bit earlier asking for help with my led strip. However I’ve now decided to add functionality.
So basically I want this code to be somewhat interchangeable (i might want to reuse again in strips of other length) so this is why I’ve decided to go with logical operators (ie the if statement to decipher between even and odd leds) even given my small strip (23 leds).
I want the first loop to play 3 times total and for the leds to fade/pulse.
My second loop is essentially a spinning rainbow cycle. played 3 times.
Here is my code so far:
#include <FastLED.h>
#define PIN 9
#define NUM_LEDS 23 //my strip has 23 leds total
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
int fadeAmount = 5;
int brightness = 0;
CRGB leds[NUM_LEDS]; //this is the array of leds
void setup() {
delay(1000); //1000 millisecond delay
FastLED.addLeds<WS2812B, PIN, COLOR_ORDER> (leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
void loop() {
for (int i = 0; i < NUM_LEDS*3; i++) //I want this loop to run 3 times
if (i % 2 == 0)
leds[i].setRGB(12,223,156); //even numbers play this color
leds[i].fadeLightBy(brightness); //this is what makes the lights fade
else
leds[i].setRGB(110,231,58); //odd numbers play this color
FastLED.show();
brightness = brightness + fadeAmount;
//reverses direction of fade
if(brightness == 0 || brightness == 255)
fadeAmount = -fadeAmount ;
delay(15);
//fill rainbow loop
void rainbow()
rainbowCycle (14);
void rainbowCycle(int SpeedDelay) {
byte *c;
uint16_t i, j;
for(j=0; j<256*3; j++) { // 3 cycles of all colors on wheel
for(i=0; i< NUM_LEDS; i++) {
c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
setPixel(i, *c, *(c+1), *(c+2));
FastLED.show();
delay(SpeedDelay);
byte * Wheel(byte WheelPos) {
static byte c[3];
if(WheelPos < 85) {
c[0]=WheelPos * 3;
c[1]=255 - WheelPos * 3;
c[2]=0;
} else if(WheelPos < 170) {
WheelPos -= 85;
c[0]=255 - WheelPos * 3;
c[1]=0;
c[2]=WheelPos * 3;
} else {
WheelPos -= 170;
c[0]=0;
c[1]=WheelPos * 3;
c[2]=255 - WheelPos * 3;
return c;
