ah one dump question… whats the output voltage of the arduino pin? the data signal should be 5v so far i remember for the specs… my teensy would provide 3.3 without the octows2811 shield…
@Severin_N It is a PC - I can not draw
yes I have tried more like 3 pins)
OK, give me few minits and i will check a voltage and signal
but tomorrow, local time is 23:35. I have to go sleep.
The Arduino Pro mini comes in 5v and 3.3v versions.
The LEDs might be SK6812s, try defining them as SK6812 instead.
Good luck
Hi guys , I am quiet bussy , at the weekend I will work on it and let you know if I succes.
@Severin_N @Jeremy_Spencer @matt_p
Hi guys
I solved this issue
It was arduino problem.
Another arduino (original arduino, not china clone) works well
Thanks alot for your time
BR
Roman
