HI…
Sorry to ask but what size are the bearings, thingyverse is down and I can’t find the needed sizes.
THX
Hi @Auzze_Auzze don´t be sorry, were here to help! =)
You need the following bearings: (measurements are: Inner Diameter x Outer Diameter x Thickness)
For the wheels (2 on each) you need 5x10x4 bearings (8pcs)
For the front, rear and central diffs (2 on each) you need 10x15x4 (6pcs)
Also, (not yet uploaded) there is an updated Steering using bearings which are 6x12x4 (4pcs)
All files are also available on GrabCAD if Thingiverse is down and that´s where i will post ALL updated files in the future, i will only upload major updates to Thingiverse!
http://grabcad.com/library/openrc-1-10-3d-printable-rc-truggy
Oh, and you need another 4 of the 10x15x4 for the drive joints…
