Hi,
Something I wanted to share and that possibly will make fdm printing compete with sls and even sla printing
To start of I invented a new type of cold end, it does not use a hobbed bolt but a belt. So there will never be any grinding of the filament anymore and way less jamming of the nozzle. I hope it will inspire a whole new type of extruders, called āv-strudersā
One of my first customers, a goldsmid, has let me know that he was able to print without any problems with a 0.1mm nozzle using moldlay wax filament. Im now searching for a place to buy a 0.1mm nozzle or even smaller so I can confirm this myself. Anyone knows a good webshop, preferably with fast shipping?
To this moment I was only able to test the v-struder with a 0.4mm E3D nozzle. In an extrusion only test, using petg 1.75mm at 235 degrees celcius I was able to extrude up to 2 meters per minute of raw filament without any slip in a bowden configuration with a bowden tube of 1 meter long. For higher speeds the filament would buckle inside the cold end in the gap between the belt and the ptfe tubingā¦ probably because the hot endās thermic capicity to meld the filament was reached.
@ThantiK
yes it is belt friction mechanism, it has a quarter Ā±40mm diameter circle perimimiter surface contact with the filament. Which is much more than the point contact of the conventional cold ends, thus less force is needed for the same or more extrusion force. Also the belt contact will never grind the filament. Yesterday I also tested filament swapping by melting the old end to a new spool and it worked perfectly.
@Rien_Stouten Good suggestion! Printed Gears are cheaper than using another belt, and the performance increase you suggest is for the time being unnecisary; first invent a fdm printer that can print 2 meter per minute raw filament Also I spend a lot of time optimising the gears to a point you dont hear them at all
Ofcourse it is opensource, build instructions and links to the files will be posted soon on youtube. Search for user vaeder3d
How does the weight compare for āconventionalā filament drive systems? Would it be possible to incorporate this type of design into the Flex3Drive, putting the motor on the frame and the belt drive mechanism at the head? Heavier or lighter as a result?
@Mike_Miller This video is one of the first prototypes (just see the date of the video), lots of small changes have happende since then. Iāll make a new video soon and post it on my channel.
@Ryan_Carlyle was faster than me, the source he cited is also a really good and detailed build. One of the issue seems to be the wear of the belt.
Now about the printerās cinematic that can sustain this kind of speed, Iām actually not that far (check some of my video) but melting the plastic fast enough is another issue.
@Michael_Memeteau Currently im doing an internship at Reprapworld and have been testing it on their printerfarm. In the beginning there were some problems with the wear of the belt, but with the latest versions there is no noticable belt wear. One machine I havent updated the v-struder for a couple of versions as a durability test and it has run for 240+ hours with only superficial signs of wear. And the beweren version run even smoother.
@Fred_U
The weight is a bit more than a conventional extruder, but I think a flex drive could be done. The only question is why would you want to do it? The power of the v-struder is that the friction caused by any reasonable length bowden tube has no effect on the performance of extrusion. On the other hand if you want to eliminate the effect of hystheresis happening in the bowden tube you just increase the amount of retraction, because with the v-struder there is ānoā slip and no grinding of the filament. Anyway the effect of the extra mass on the moving head will effect the performance way more than the effect described previously. Hope this answers your questions and more
