Hi Please could you help.
Hi
Please could you help. I have downloaded the SmartRapCore GITHUB files to my PC and open the Source files in OpenScad. I make some changed to the rod size and board thickness and Rendered the file.
Now I want to export the printable STL files , however when I click on export STL, it giles me a STL file with the Box and everything. Not just the Printable parts.
How do I select the part and export only the part I want as a STL file ?
I checked the net with no joy.
Please help.
Thanks
Make a try with the “Takerbot” files:
Thanks @Erich_HaHaOh The only problem I have is that the thickness of the Board is not the same as those STL files. Also not sure if its using 8mm rods etc.
My measurement for the rod is always under 6mm
Problem of ViaCad with existing stl-files.
https://photos.google.com/u/0/photo/AF1QipP0kBfDeMmxadzV0Y-f7ZAoZznsbx_HNEoXlwc
https://photos.google.com/u/0/photo/AF1QipOF7ECpux9N6PkGb3ZsBIwGGU_EMY956Ptx-Q0
