Hi, newbie alert. My first laser, it is having the problem of not firing at full power.I get the low intensity light cycling on and off but no burning, It is the Gearbest 2.5. It burns when connected to the 12v fan connector. I am using GRBL 1.1 and LW3. I switched the board jumper over as per instructions and I changed $100 and $101 so the movement is to proper scale. My settings are:
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=83.00
$101=83.00
$102=250.00
$110=500.00
$111=500.00
$112=500.00
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
Any suggestions would be greatly appreciated. Thanks, Jim
I have same laser and Elks Maker board. Same issue.
I have changed $32 to 1 changed $30 to 255 then to 1000
I’ve also then changed PWM max S value to 1000 in the LW3 gcode settings. laser does indeed light up brighter on the change to 1000 for PWM but still doesnt burn.
Next test is to reset back to 255 and plus laser cable into 12V fan slot on board…
Okay… tried the 12v fan slot and laser powers up and starts burning immediately… not a good idea. Rather unsafe. At least I know the laser works… just need to power it properly.
FYI … I too have flipped the board jumper as per Jim original post and as per Jords YT vid.
Okay… tried another file type. Not a .png or .jpg but got LW3 to convert a .jpg to a vector file (.svg) … viola … laser now powering.
Will try with a straight up .svg file that not vector converted to see if that works
I did the gradient test and I cannot get grays to print. It’s either on or off. I did have good prints using the dither technique. Basically prints the grays using tiny dots of black. Anyone have any different experience?
2.5W diode from gearbest. I didn’t know how cheap Co2 was at the time. Missed the boat since I wanted to do etching on metal. You’re saying I CAN do grayscale with my diode?
