Hi, new laserweb user with K40 and cohesion3D mini board. I have laserweb up and running perfectly now but would like to know if there is a way for the laser to run a contour of the area that will be worked before actually engraving? I would like the laser to outline the engraving area so you can better position the material. I have seen this in other software like T2Laser but cant find it in laserweb.
thanks for any help
Y es, there is a Button in control screen.
Try the “check size” button on the control tab
Hi Roberto, thanks for the reply. You mean the check size button?
thanks, will give it a go.
