Hi laserweb community! I downloaded LW4 and love the interface and usability, but i need help with one thing, the LW4 orientation is bottom left, but my machine is top left, is there a way to change the 0,0 so the two align? I would like to use the top left as 0,0 because that is where the beam comes out of the machine, any help is greatly appreciated!
@Baxter_Smith welcome. Have you first set up your firmware to home too left? Are you on GRBL or Smoothie?
@Ariel_Yahni_UniKpty thanks! using Smoothie with the C3D mini board. M115 found top left and G28.2 zeros home there but the display still shows home as 0,0 bottom left, i could switch the y end stop to the bottom of the machine but wanted to keep top left as 0,0 for proximity laser beam
Get the lastest version please. You will notice 4 arrows on the grid when you do
The go to Settings/Machine and type -200 on the Y axis and test. @Todd_Fleming is this correct? I haven’t tested it
@Ariel_Yahni_UniKpty @Todd_Fleming that worked! thank you both so much, i can now laser cut from the top left! and i downloaded the latest version, cant wait to play more with this awesome tool
@Ariel_Yahni_UniKpty @Todd_Fleming is there a time estimate for laser cutting parts? i cant find one and have been searching to boards, there seems to be one for cnc but i cant find the one for laser cutting. do you have any input? thank you again for your help!
