Hi, I've some encoding issues with Serial Port JSON Server.
Hi,
I’ve some encoding issues with Serial Port JSON Server. It works perfect, but i need support of some latin chars encoded in Windows-1250. It’s problem when I want to send ASCII code like 0xB9 with “send” command - it’s sends escaping char before 0xB9 (0xC2). Is there any way to bypass this escaping? In other words I’m delivering correct string in Windows-1250, but SPJS sends escaped string. Please help - if it’s possible. Thanks!
OK, I’ve resolved my problem after digging in sources and adds some replacing escaped characters in write method
Cool. Glad you found it. Could you do pull request
