Hi, I'm planning a project using either 3 (or possibly 5) Neopixel 12 LED
Hi, I’m planning a project using either 3 (or possibly 5) Neopixel 12 LED rings, a Wemos D1 Mini and a power bank.
For wiring purposes I’d like to connect each ring to it’s own pin on the Wemos. Does this mean that each ring will display the same animation at the same time? Or is it possible to send different data to each ring?
@Cogwun it’s possible to send different data to each pin
here is the documentation
