Hi,
I’m not sure to buy a K40. On one hand I’m very excited what nice stuff I could create with this machine. On the other hand I wonder if there are drivers and software to run a stock K40 on a Windows 10 machine.
Any hints?
Hi,
Any hints?
They say whisperer should work on win10.
I had a laptop with W10 on it and I used Coreldraw12 with the stock drivers. The laptop died, I picked up a W7 machine for 80 bucks on craigslist and it runs the same software.
So Whisperer will work with the stock K40 controller or do I have to change the controller board?
@Michael_Weber I have K40 Whisperer running on my stock K40. You do have to install some USB drivers, but they work fine for me on my Win7 box. The only thing I’ve updated (so far) is adding an air assist and a new ZnSe lens. I did buy a #Cohesion3d mini board to upgrade it (and then use lightburn software), but I haven’t done so yet, simply because K40 Whisperer and Inkscape works well enough for me at the moment. Here is a link with the details about it.
http://www.scorchworks.com/K40whisperer/k40whisperer.html
I like to hear it works with Inkscape. For my cutting plotter I create vectors using Illustrator end import them into Inkscape. That works very well. So I hope a K40 will do so as well
Thanks!
@SirGeekALot I still have my Gerbil Kickstarter in the box, as I have great results, and a good workflow with inkscape and k40 whisperer…
