Hi, i’m choosing an air pump for the air-assist, are there any recommendations for minimum flow-rate and pressure ?
hanks.
hanks.
I bought a airbrush compressor and it was a waste of money, I’m now using my big compressor and running it at 25 psi, works great.
Thanks Scott, what’s the flow rate on your unit ?
I have no idea what the flow rate is.
Just a 40 gallon shop compressor. 1/2 horse motor.
Okay, thanks.
I am using a 1/2 hp shop air compressor with adjustable regulator with built in water trap-otherwise u will get water coming through the air line sometimes
Thanks for info all
