Hi,
I was wondering whether there was an easy way I could make the 16 colours i have in a colour palette bleed into each other more?
Are you already using ColorFromPalette( … LINEARBLEND) ?
How different are the colors? Could you share some code so we can see what it looks like as-is?
Hmmm, Yes i’m using ColorFromPalette but I can’t see any blend functionality stuff in this. I’m using your NoisePlusPalette.ino: https://github.com/FastLED/FastLED/blob/master/examples/NoisePlusPalette/NoisePlusPalette.ino
Look at the palettes example, if you just run the example sketch you can see the effect of linearblend
