Hi!
I need your help:
I tried to print this model on PLA and using 200 deg, the first line is the results of the printing when the fans on the top of the printer was stopped to work, the other two lines is with the fans working (but after each layer I need to fix it back to 50% because it drop back to 20%)
the first 3 layers is printed very well but the others (when it’s start to build the walls) goes wrong.
can anybody here tell what is the problem?
is it the fill rate or the temp or just a printer problem?
it’s my first try.
