hi i`m new lasering game i got makerbase mks dlc32 v2.1 it connect to my computer ok the laser turn on and off but the X and Y do not move any idea i am useing laser grbl software a friend has said i need to Download TS24‑R firmware i can not find it anywhere or download MKS DLC32 TS24‑R firmware TS24‑R firmware
- DLC32 Laser firmware
- UI packs
- ESP32 partitions
- Beta firmware version
can anyone help out please
The DLC32 connecting while the laser output works but X and Y stay still points more toward a motion/firmware or controller configuration issue than the laser itself. Check that LaserGRBL is using the correct serial port and baud rate, then verify the controller reports normal GRBL startup text and accepts a simple jog command before changing firmware.
thank you for getting back me The band rate is correct as well as the serial port and will accepts jogging command but does not move when i look at the $$ code there is a blue cicrle with an ! in the middle whn i look at the small screen board MKS DLC32 CNC V2.0 and FIRMWARE V2.1.0 (8M.H24.20220511) i been told this is wrong and i need to download
mkstft24.bin Version: 20220526
Model: TS24‑R V2.1
Mode: Normal (Laser + CNC)
Board: DLC32 V2.1 Is the correct as i can`t find it your help would very greatfully
hi there
thanks for back i have working away a bit
I`ve check correct serial port and baud rate and verify the controller reports normal GRBL but when it check the $$ setting there is a round circle with a question make inside could this be the problem thank help in this matter
thanks for your reply how do i check motion/firmware or controller configuration and verify the controller and see the reports i
i`m using laser grbl and when i check the $$ i have a bluecitcle with a ! mark
I`m using DLC32 laser v2.1 2023120602 firmware
