hi i just got a 3d pen can you use any 3d pen brand filament thanks
yes
thanks
Yes, but depending on your pen you should check filament diameter (1.75 or 3mm) and that you can set the temperature for ABS or PLA.
With the 3Doodler, I found that it was quite important to use straight filament, like the rods that it’s sold with. Filament that comes off of spools can be curled, which tended to cause problems in the straight pen.
thanks
