Hi,
I had a small fire inside my K40. It melted the X axis drive belt and damaged the laser carriage too too so I have replaced them.
The only other part that looks damaged is the gear wheel / pulley for the X axis on the opposite side to the motor. I believe it is a 20 tooth 3mm idler so will order that. However, I cannot figure out whether the pulley bracket holding it is damaged. It is hanging loose and I am unsure if that is just because the belt is not attached or if there should be plastic spacers on those screws holding it in place.
Photos are attached (second shows bracket I am referring to and damaged pulley) so if somebody with a fairly standard K40 could have a quick look at their machine and see what the bracket should be like, that would much appreciated!
Thank you.
