Hi I downloaded serial-port-json-server_macosx_v1.80 and read the readme file.
Hi
I downloaded serial-port-json-server_macosx_v1.80 and read the readme file. The terminal command needs a sudo to ask for a password and then nothing happens. Is this a precompiled executable app or do I have to compile it?
I reloaded chilipeppr and it still unable to lock into a serial port. does the tinyg has to be connected and powered up?
Thank you
It’s already compiled, so just run it. Yes, the tinyg needs to be connected and powered or your computer wouldn’t know it’s there and thus spjs and chilipeppr wouldn’t know either.
You will also need to direct chill pepper to local host if running on same machine. The serial port server allows splitting of connection computer and chill pepper interface.
Thank you both.
