Hi, having some troubles to setup initial configuration of my RepRap Prusa Mendel and especially Skeingforge settings. Manual driving works just fine.
Anyone wants to push me to the right direction?
You may want to consider using Slic3r http://slic3r.org/ to start off. There are not as many settings.
Does it work with Printrun?
Yep! Steps are 1. Open .stl file in Slic3r 2. Change your print settings in Slic3r. 3. Then click on the “Export G-code” button in Slic3r. After your gcode file has been generated click on the “Load File” in Pronterface and click print.
Thanks! This works so well. My fist mistake was that I tried to use slic3r somehow via pronterface gui. Thanks a lot!
