Hi guys. Im having issues with GRBL (homing). Im using LW3 to control the router (self made). Is this the right place to ask for help or i should go elseware?
Cool!, so, new grbl install, im using mechanical switches. I have 2, per axis, in series.
The router haves a fixed gantry (x axis) and moving table (y).
When i hit home the moves moves towards the front and x to the right and on LW i see it´s at 0,0, so, the positive space is to the left and front. I played with the invert masks for the axis and homing dir, but didnt found a combination that works.
Its a silly problem, but looks like im having a dumb day and i cant find the solution.
Ok, so i have recompiled grbl using the HOMING_FORCE_ORIGIN option. Now its looking good, now its not more forced on negative space, so, its all good.
Now im having another problem.
Im using:
#define HOMING_CYCLE_0 (1<<X_AXIS) // COREXY COMPATIBLE: First home X
#define HOMING_CYCLE_1 (1<<Y_AXIS) // COREXY COMPATIBLE: Then home Y
When Y hits the endstops, it raises an alarm and it ends there, x doesnt homes.
