Hi guys,
I was wondering about my extraction system and i’d like to know if you can provide the dimensions and type of plug of the air exhaust or it’s a bit early and things may change ?
Thanks !
Max
Hi guys,
Thanks !
Max
Hi Max,
A few of the others are keen to know too but we cant be 100% sure yet as we are adjusting the build a little to make it fit on a European pallet.
We are also considering creating 2 options for the vent, back and the side. So you can choose where best to extract from depending on the space you have.
The hole itself will be for a 100mm diameter hose.
Ok no problem I just needed the 100mm size for now The ajustable vent position is great new !
100mm, check! I can proceed with my exhaust system as well now! (The part from the fan to outside is all done, now I can prep the fan->FABkit part)
