Hi Guys,
i like to use the comand G64 but it dont work.
If i mill a Curve (not round) or an Text the machine stops after every line
i like to mill the Curve at once not in hundret litle lines
please help
Hi Guys,
please help
Check out https://github.com/synthetos/TinyG/wiki/Gcode-Support and the dicussion on G64 behavior.
Is that what you are seeing/getting?
I did it but by g61 does nothing change the machine stops after every 0.1 mm by milling a curve
I solved the problem
I sendet to less gcode at once to the tinyG and i mill with up to 4500mm/min so it was to less code and than …
What do you use as a Gcode sender and how do you have flow control configured?
Good to hear you have a solution, but flow control should be adequate to keep buffer from overfill.
Now i send 1000 lines at once direct from my laptop over usb the maximal allowed offset is now on 0.05 mm
And it works fine now
