Hi guys. I have a big problem. I can’t use my cnc laser because i don’t know connect it to the software.see video.I try on it on 3 Pc. Two windows10 and 2 on windows 7.i installed two kind of drivers correctly. Seller don’t respond me.I am desperate. Thank you if you know help me.
https://youtu.be/PI-wIXttkBQ
open source Grbl like this? http://www.ebay.it/itm/UNO-R3-CNC-SHIELD-V3-4-Pcs-A4988-DRIVERS-/272662258437?hash=item3f7befe305:g:LW0AAOSw65FXwtbw
Save yourself a lot of trouble and go with @raykholo 's cohesion3d Mini. Otherwise you will have hookup issues. Not to mention, support will be much friendly. Ray’s board is essentially a swap in.
I wondering why you posted here? You don’t seem to even be using LaserWeb. Is that correct? I would recommend taking advice above and then use LaserWeb4 to run it. Otherwise, you may want to check out this community. Your machine likely uses a counterfeit chips and finding the correct driver can be like a treasure hunt.
https://plus.google.com/communities/109476961016291692936
thank you
