Hi Guys i am looking at my first part change on my machine and
Hi Guys i am looking at my first part change on my machine and after looking at the mirror’s they have scratch’s on them and the machine is not cutting that well so what lens upgrade should i look at don’t want to spend a bunch of money as this is a hobby thing for me.
Dennis
Here’s some options from LightObjects.
http://www.lightobject.com/Lens-Mirror-C16.aspx
Depending on what exactly is scratched, I would just replace that part on it’s own (since you mention it is just hobby for you).
However, I am fairly sure you can get sets of lens/mirrors on ebay as well. The mirrors are usually Mo (molybdenum) & the lens ZnSe (Zinc Selenide).
Yuusuf
I have been looking on ebay and light objects for lens and mirrors, question all that i have seen are larger then the standard part what dose that mean i have to change the holding fixture as well whats the story on the light objects air assist lens fixture it takes a larger lens would this change the power of the laser would it be better or worse
Dennis
wow looking at light object sure can spend some money on mirrors and lens
Can’t remember the details but the standard lens holder accommodates a smaller lens than the light objects air assist head. The light objects head is 18mm, the supplied lenses are 12.5mm if I remember correctly.
I’ve bought a few lenses off ebay from saitecutter (http://www.ebay.com/usr/saite_cutter) cheaper than lightobjects and good quality.
Thanks for the response i will take a look at them
Dennis
I use saite cutter as well1. Decent quality
