Here is a listing of messages
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega1284p -DF_CPU=12000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -ID:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\hardware\Calunium\cores\arduino -ID:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\hardware\Calunium\variants\pcb -ID:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED C:\Users\Folny\AppData\Local\Temp\build4404778257253151125.tmp\RGBCalibrate.cpp -o C:\Users\Folny\AppData\Local\Temp\build4404778257253151125.tmp\RGBCalibrate.cpp.o
In file included from D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/FastLED.h:24,
from RGBCalibrate.ino:1:
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/chipsets.h:405:2: warning: #warning “Not enough clock cycles available for the GW6205@400khz”
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/chipsets.h:419:2: warning: #warning “Not enough clock cycles available for the UCS103B@800khz”
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/chipsets.h:433:2: warning: #warning “Not enough clock cycles available for the WS2811 (800khz)”
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/chipsets.h:456:2: warning: #warning “Not enough clock cycles available for TM1829@1.6Mhz”
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/chipsets.h:462:2: warning: #warning “Not enough clock cycles for LPD1886”
In file included from D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/FastLED.h:23,
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:16: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:39: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:62: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:85: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:109: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:119: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:131: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/colorpalettes.h:145: warning: only initialized variables can be placed into program memory area
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/clockless_trinket.h: In member function ‘void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::showAdjTime(const uint8_t*, int, CRGB&, bool, int) [with unsigned char DATA_PIN = 6u, int T1 = 4, int T2 = 4, int T3 = 5, EOrder RGB_ORDER = RGB, int XTRA0 = 0, bool FLIP = false, int WAIT_TIME = 50]’:
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/clockless_trinket.h:32: sorry, unimplemented: inlining failed in call to ‘void _dc(uint8_t&) [with int CYCLES = -0x000000001]’: recursive inlining
D:\LED STRIP PROJECT\Arduino Original\arduino-1.0.5-r2_ciste\libraries\FastLED/clockless_trinket.h:22: sorry, unimplemented: called from here
