wel i couldn’t figure this one out myself… Can anyone help me with the code?
my setup is following:
64 led strip covering the Left - TOP - Right- and side of the screen.
Connected to the arduino pins on GND - 13 and 11
to cover the buttom part of the screen i have the same looking ws2801 led strip. but this one uses RGB instead of the RBG color profile.
i connectet the new led strip on the ending part of the WS2801 by soldering the 4 points.
does this mean i have to desolder the new ws2801 thats meant to cover buttom part of my screen and have GND - 5V - CK - SPI connected to new pins on arduino?
or can i leave those connected to my WS2801 RBG profile which are covering LEFT TOP AND RIGHT side of screen?
the code i use in arduino are as follow:
// Slightly modified Adalight protocol implementation that uses FastLED
// library (http://fastled.io) for driving WS2811/WS2812 led stripe
// Was tested only with Prismatik software from Lightpack project (version 5.9.1, 5.9.6 and 5.11.1 so far - 5.11.1 has some issues on startup in windows so I’m not using it)
#include “FastLED.h”
#define NUM_LEDS 92 // Max LED count
#define LED_PIN 11 // arduino output pin - probably not required for WS2801
#define GROUND_PIN 10 // probably not required for WS2801
#define BRIGHTNESS 128 // maximum brightness
#define SPEED 115200 // virtual serial port speed, must be the same in boblight_config
CRGB leds[NUM_LEDS];
uint8_t * ledsRaw = (uint8_t *)leds;
// A ‘magic word’ (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch). You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided – fewer false positives. The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55). LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
static const uint8_t magic[] = {‘A’, ‘d’, ‘a’};
#define MAGICSIZE sizeof(magic)
#define HEADERSIZE (MAGICSIZE + 3)
#define MODE_HEADER 0
#define MODE_DATA 2
// If no serial data is received for a while, the LEDs are shut off
// automatically. This avoids the annoying “stuck pixel” look when
// quitting LED display programs on the host computer.
static const unsigned long serialTimeout = 150000; // 150 seconds
void setup()
// pinMode(GROUND_PIN, OUTPUT);
// digitalWrite(GROUND_PIN, LOW);
// FastLED.addLeds<WS2811, LED_PIN, BRG>(leds, NUM_LEDS);
FastLED.addLeds<WS2801, 11, 13, RBG>(leds, NUM_LEDS);
// Dirty trick: the circular buffer for serial data is 256 bytes,
// and the “in” and “out” indices are unsigned 8-bit types – this
// much simplifies the cases where in/out need to “wrap around” the
// beginning/end of the buffer. Otherwise there’d be a ton of bit-
// masking and/or conditional code every time one of these indices
// needs to change, slowing things down tremendously.
uint8_t
buffer[256],
indexIn = 0,
indexOut = 0,
mode = MODE_HEADER,
hi, lo, chk, i, spiFlag;
int16_t
bytesBuffered = 0,
hold = 0,
c;
int32_t
bytesRemaining;
unsigned long
startTime,
lastByteTime,
lastAckTime,
t;
int32_t outPos = 0;
Serial.begin(SPEED); // Teensy/32u4 disregards baud rate; is OK!
Serial.print(“Ada\n”); // Send ACK string to host
startTime = micros();
lastByteTime = lastAckTime = millis();
// loop() is avoided as even that small bit of function overhead
// has a measurable impact on this code’s overall throughput.
for (;
// Implementation is a simple finite-state machine.
// Regardless of mode, check for serial input each time:
t = millis();
if ((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) {
buffer[indexIn++] = c;
bytesBuffered++;
lastByteTime = lastAckTime = t; // Reset timeout counters
} else {
// No data received. If this persists, send an ACK packet
// to host once every second to alert it to our presence.
if ((t - lastAckTime) > 1000) {
Serial.print("Ada\n"); // Send ACK string to host
lastAckTime = t; // Reset counter
// If no data received for an extended time, turn off all LEDs.
if ((t - lastByteTime) > serialTimeout) {
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB)); //filling Led array by zeroes
FastLED.show();
lastByteTime = t; // Reset counter
switch (mode) {
case MODE_HEADER:
// In header-seeking mode. Is there enough data to check?
if (bytesBuffered >= HEADERSIZE) {
// Indeed. Check for a 'magic word' match.
for (i = 0; (i < MAGICSIZE) && (buffer[indexOut++] == magic[i++]););
if (i == MAGICSIZE) {
// Magic word matches. Now how about the checksum?
hi = buffer[indexOut++];
lo = buffer[indexOut++];
chk = buffer[indexOut++];
if (chk == (hi ^ lo ^ 0x55)) {
// Checksum looks valid. Get 16-bit LED count, add 1
// (# LEDs is always > 0) and multiply by 3 for R,G,B.
bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
bytesBuffered -= 3;
outPos = 0;
mode = MODE_DATA; // Proceed to latch wait mode
} else {
// Checksum didn't match; search resumes after magic word.
indexOut -= 3; // Rewind
} // else no header match. Resume at first mismatched byte.
bytesBuffered -= i;
break;
case MODE_DATA:
if (bytesRemaining > 0) {
if (bytesBuffered > 0) {
if (outPos < sizeof(leds))
ledsRaw[outPos++] = buffer[indexOut++]; // Issue next byte
bytesBuffered--;
bytesRemaining--;
// If serial buffer is threatening to underrun, start
// introducing progressively longer pauses to allow more
// data to arrive (up to a point).
} else {
// End of data -- issue latch:
mode = MODE_HEADER; // Begin next header search
FastLED.show();
} // end switch
} // end for(;
void loop()
// Not used. See note in setup() function.
