Hi folks, I built my first FastLED based lamp. This lamp was built from a “fish lamp” , height around 100cm, diameter 10cm
Outside I glued a satinied foil. Inside I put an A1 white paper.
A 54 RGBLed stripe is used and controlled with an arduino nano. Via quadratur encoder it is possible to change brightness and/or pattern.
Hope you like the video.
Yes, the image is not my lamp, it’s only an example . Will be honest, in Germany the lamp is called “Blasenlampe, Sprudellampe, Wassersäulenlampe,…” Not sure what is the real correct name
