Hi everyone I need help.
Having problem with the cutting power.
I’m using C3D board with grbl-PLC,pot set to max,
$33=5000 (for cutting).and pin 2.5 for PWM.
The problem is when I start cutting my max mA is only 10mA but when I use the manual test fire I have 20mA.
Any advice.
Thanks in advance.
What does $33=5000 mean?
@Ariel_Yahni_UniKpty $33=5000 means is PWM frequency. But it’s working properly now. I just have to update everything.
Thanks.
It would be good that you post how it was fixed for others to reference from it
