hi :D im having a problem with x and y coordinates.
hi :smiley: im having a problem with x and y coordinates. when i move them in laserweb they dont change.
What firmware are you using?
You are using grbl?
If true, can you check if is in your grbl setting S10=0?
@Joan_Sunyol yeah im using grbl
its S10=3
@Ruben_Castanho must be 0
its solved :smiley: thx very much man!
hi, if i put $10=0 (which is very useful for real time track) it set automatically the offeset as this “Work Offset: -109.66 / -300 / 0 / undefined”
is it possible to stay with offset 0 /0 / 0 ?
@Antonio_Giudice try and change show machine to off in settings
@Ariel_Yahni_UniKpty thank you, however i rather prefer $10=3 than show machine off :slight_smile:
