Hi community, I am finishing off a prusa i3 vanilla build and want to
Hi community, I am finishing off a prusa i3 vanilla build and want to use the nema 17 extruder with an e3d v6. Problem is the extruder has a flat mating surface for the hotend and the e3d v6 is groove mount. Does anyone know of an adapter. I don’t want to use wades or gregs extruder.
Is there a 3 mm version.
The comments should have the changes that allow the e3d to work with the original scad version. There should be settings there for 3mm.
Ok thanks I am on my phone atm will look at it later.
