Hi can you tell me if the grbl chillipeper is now set to work
Hi can you tell me if the grbl chillipeper is now set to work with the new grbl 1.1 firmware, sense somethings was changed?
We would all welcome new/different members of the community testing it out and letting us know. I have heard that there is a feed rate override in grbl 1.1. You could mimic the way feed rate override was done in the TinyG workspace, because I find dynamic feed rate control to be one of the most important aspects when running long jobs.
yes you an adjust feed rate in real time witch is awsome, i use UGS platform, so i was wondering if there was any updates in Chilipeppr to suport the grbl 1.1, cause was add some new features with new comands, have a look “https://github.com/gnea/grbl
Would you be up for adding them to ChiliPeppr Grbl workspace? You could fork your own version of that workspace to tweak stuff, and then do a pull request back to the main workspace. I’m sure everyone would appreciate it.
unfortunatly my programing skills not that good
@vMeph alguien del publico que pueda ayudar, hay una versión para arduino mega 2560 GitHub - gnea/grbl-Mega: An open source, embedded, high performance g-code-parser and CNC milling controller written in optimized C that will run on an Arduino Mega2560
trato de conectarla con chilipeppr pero no me deja
trato de conectar la tarjeta mega con el https://github.com/gnea/grbl-Mega/ , la selecciono en Serial Port JSON pero inmediatamente se desconecta.
https://github.com/gnea/grbl-Mega/, esta version esta corriendo en la tarjeta arduino mega 2560
thats version 1.0 for the mega, in arduino uno you have version 1.1d
