Hi,
Anyone know why this is happening. When i mirror a textbox upside down it engraves the correct way up?!? I am using CorelLASER x7. Anyone any idea?
Hi,
Looks like the special formatting doesn’t transfer… thats interestingly odd. your text is technically vertically inverted… what if you were to rotate the normal text 180 degrees to be horizontally inverted will it then carry over?
Unless of course if you’re looking to do a reflecting pool type text layout, then that may be an issue…
I’ll give it a go with rotation. Just strange that this happened!! I thought I was going mad when it was engraving!
Lol I can understand that
