Hi all. New here, just got my K40 this weekend.
Hi all. New here, just got my K40 this weekend. I’m using correldraw x7 and corelLaser. When I press the cut button, in the next screen you can set the cutting speed. No matter what I put there, the speed will always be something like 2 mm/sec. I’ts not possible to cit cardboard at his speed, it will catch fire. Is there a way to increase this speed.?
Make sure you set the Board ID & the Model on the Device Initialise settings page. see: https://drive.google.com/file/d/0Bzi2h1k_udXwbERTbWdISGY5eVU/view?usp=sharing
Also, make sure to set the CorelDraw settings too. see: https://drive.google.com/file/d/0Bzi2h1k_udXwWVlDR3RyTzlzemM/view?usp=sharing
Hopefully that will sort out the issue.
@Yuusuf_Sallahuddin_Y Yes, this was the exact problem I had when I first used my laser, as I had not set the Board ID.
Thanks for the help. It turns out that the wrong board was selected. LaserDRW had the correct board setting. After copiing that setting into corel everything works fine
