Hi all, My designed piece is never the same size as the printed piece.
Hi all,
For instance, if I design a box with 2mm wall, after printing the walls are 3mm.
And the overall size of the box has 1mm extra comparing to th design…
Any clue on the reason ? I thought it has to do with the number of perimeters, but event when set to 1, the problem remains.
(printer is a flashforge creator pro)
Thanks
Edit: maybe I found the cause. Horizontal compensation was set at 0.5
