Hi all.
In cncweb, Is it posible set the 0 point for x and y axes separately? I want to use a digitizing probé in other to calibrate the 0 pont in x and y.
The idea is place an aluminiun pieze, calibrate x and y touching the aluminiun with the probé, firts x and then y. After this, the cnc can start the job.
Actually, the 0 point is calibrate at the same time for both axes.
Smoothie with cbeam Machine from openbuilds.
But, with macro buttons I do not know if it is posible. I need to move the axes by hand, with the jog arrows.
May be, if I put the axe at Edge of the table and with macro buttons go to find the aluminio pieze… When the probe, touch the aluminium, the point 0 Will Be stored.
Then, the same for the other axe.
