Hi All,
I’m using FastLED to control a strip of 150 WS2812B LEDs.
I’m trying to animate a palette and was hoping to use the “heatmap” method so I I can easily increment positions and have a smooth gradient between each position:
byte pos1 = 94;
byte pos2 = 132;
DEFINE_GRADIENT_PALETTE(pal) {
0, 194, 1, 1,
pos1, 1, 29, 18,
pos2, 57,131, 28,
255, 113, 1, 1};
The intention would be to change the pos1 and pos2 values between specified min and max values using EVERY_N_MILLISECONDS…
As far as I can tell, “DEFINE_GRADIENT_PALETTE” only sets the palette once - at startup.
Is there a different way I can achieve this?
Many thanks for any help you can offer.
