Hi All, I just started with Laserweb and I already have an issue.
I’m using the Inkscape 0.91 and LW 4.0.991 I’m about to finish my engraver and can’t get the shapes filled, it looks fine in Inkscape and InternetExplorer but there is no filling in LW.
I also get a “The file has minor issues” error but this doesn’t help me.
I attach the results.
unfortunately, I have also no idea how to upload the SVG file.
@Martin_von_Gunten
So because its saved By .Svg
that is why its not filled … u want to engrave so save it .JPJ Or png
and it will be filled … good Luck
Thanks, again for your reply. But I didn’t choose any operation to mill or engrave at this moment.
I works with the litte dot but not for the “handdrawn” circle with the z.
If they would be shown as black I would be able to pocket mill them. Tinu
recheck that the items have fill enabled and set to black and re-save. inkscape has done this to me a few times and for some reason saving a new copy usually fixes it(ctrl-c and drop into new sheet not just a new file name) hope one of those fixes it for you
Fill color of countours is not supported with SVG or DXF. You can fill a path in LW4 by adding a “Laser Fill Path” operation for that contour in LaserWeb.
