Hi all,
can anyone advise me, what glue to use to glue abs and pla parts?
Here’s a great resource for such questions:
http://bfy.tw/8eFg
http://bfy.tw/8eFg
I try to glue abs to pla with super glue now
I’ve found a good quality epoxy works for many plastics. If you get 5 minute epoxy, it cures quickly and is less strong than 30 minute epoxy.
Thanks for the help Frank. I will try super glue first and then if it does not work, I will try epoxy.
Sorry, I ment Fred
I use Krazy glue. Gives you just enough time to move parts around a little for adjustment and sticks really well after about 1 min. Let it cure over night and you have a really strong bond.
Good quality two component epoxy glue is what I rely on, works perfectly.
Cut off zip tie ends are great stirring pins.
@Marc_Pentenrieder acetone, apply small amount with a dropper, wipe on contact areas and press ABS parts together presto.
@Jeremiah_Coley I want to glue abs and pla, not abs to abs
Thanks to all for commenting
@Marc_Pentenrieder got it I’d go apoxy then.
