Hi again, what lenght are the Universal Shaft Drive Joint please, need to order some off ebay.
THX
Is this what your after? https://plus.google.com/u/0/photos/104892210945151500865/albums/5831071430922875713/5870699805662244418
Stuart
Ah, ok! Away from my co,åuter right now, here´s some info and link to CAD file: https://plus.google.com/u/0/104892210945151500865/posts/XxhjvbeWT8b
I can provide a proper drawing if you like!
No, just need the lenght so I can order the right one.
OK, I will fix that as soon as I’m back at the office!!!
Ok, the product page clearly states 118mm but when i measure my CAD model it´s 78mm + 31mm which adds up to 109mm and NOT 118mm so there´s something not right here. I would like to verify these dimension by measuring the driveshafts but they are at home and i won´t be able to do so for several hours!
I happy to wait, thanks for the extra help on this matter.
Correct dimensions are 78 + 40mm! Let me know which ones you will buy and i will order the same…
Hi…
No, been very busy today… hope to over the week-end.
@Szymon_Kobalczyk I think the ones in the first link you posted that are 82+37mm will be best… The wishbones will most likely need to be modded but I can do that for you if you can’t do it yourself…
HI…
I have not ordered any stuff yet as I have been busy at work. but I will be ordering that size, if you could re-size the wishbones that would be great. Thanks
Ok, If you order those i mentioned above i will order the same ones and modd the wishbones to fit them!
@Szymon_Kobalczyk For the inner one i have used 3,0 or 3,2mm stainless steel rods and the outer 2,0mm stainless steel rod…
