Hi. After replacing my spoilt adapter, another part of my printer broke down. This time is the end effector. One of the fan on the cooling system is stop spinning, causing filament to be block within the effector. Anyway to fix it?
Easy Arts promised to publish all hardware sources/vendors. Some of them are included in the manual. Can you find the fan?
Attempt to fix failed. With smoke and burned fumes. Now both fans stop to spin. Really need a replacement 3d print module from Easyarts.
