Hey y'all, I'm relatively new to laserweb (and laser engraving), but really enjoying laserweb.
Hey y’all, I’m relatively new to laserweb (and laser engraving), but really enjoying laserweb.
Regarding vector fill paths: I’m engraving the negative space around (big, bold) text, and I’ve messed around with the settings enough to get a decently reliable fill, but I just don’t love the way the horizontal lines look, and also laserweb’s algorithm picks a pretty weird pattern of engraving them (skipping around the design a bunch)–not that the latter is much of a big deal.
I was wondering if it’s possible to do something like:
a) instead of filling the space with horizontal lines, basically do a series of progressively smaller “laser cut inside” operations–tracing out the letters in a smaller and smaller fashion to fill the space
or
b) do a crosshatch (or similar pattern). like a pass of horizontal lines, and then a second pass of vertical lines.
is anything like this possible with laserweb?
You can do your own crosshatch using the angle feature in that operation. So do one with 45 degree and the other inverse
The files is called Deg
Ohh! I never understood what that angle parameter was for. I’ll try that out, thank you.
What about (a)? I was able to do it manually in illustrator by copying the path and applying the ‘offset path’ operation a ton of times. (See attached svg and gcode). I wonder if there’s any way for laserweb to do that? (it’s way too much effort in illustrator)
files: https://drive.google.com/drive/folders/0B4onxH2pQeOnYzFVV1g4WERUeWs?usp=sharing
@Jacob_Evans that’s more of design relayed thus I don’t see any software making that for you. If you feel that you want the burn to be more black then the laser diameter must be at 0.1
